メインコンテンツにスキップ
iPod Original、Mini、Shuffle、Nano、Touchを含むほぼiPod全モデル用の解体ならびに取り付けガイドです。
6220回答 すべてを表示
water damage, booting up no screen
My ipod got wet. Can't see anything. It's restoring and finally showing up on itunes, but I can't see anything. What do I replace?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Cheryl, the first thing I wold recommend is that you clean your iPod. This will prevent and corrosion damage later on. Use this guide to clean it. It was written for a iPhone 3G but all the steps still apply to you. Pay particular attention to your connectors and cable ends. Once it is clean, re-evaluate. Replace the LCD if you have no result from it. If that does not work, you may have shortened out components on the logic board. Since you did not tell us which model iPod you have, I can not tell you what IC you may have to look at. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cheryl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 290
