メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Fix for main speaker after water damage?!?
Galaxy III was splashed with water. I pulled the battery, wiped it down and left it open over night. Seemed to work fine for 2 days after. Then I heard the speaker humming when it was on the charger. Pulled the battery again and left it open. Now I noticed condensation inside both cameras and the flash. I let it air out and the condensation disappeared after a few hours. The next day all seemed to work fine (Wi-Fi, music, calls, texting, internet, touch screen and so on) but with in hours the main speaker just quit, not even a hum, crackle or buzz. Calls, headphones, and wifi direct still sound fine.
How do I fix or replace this speaker? Is this speaker gone for good? Will one of your dry bags save it eventually? (ah, if only I knew they existed before) I'd much rather buy one of your bags and tool kit than pay that evil deductible for a replacement.
thank you in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I dropped my revvel phone in oil by accident now my volume won't work to we'll I have it on the highest voice and it's super low how can I fix this, I don't have insurance on my phone.
さんによる
コメントを追加
9件の回答
ベストアンサー
I had the same problem. I took the mainboard out of the phone and soaked the top part in 91% rubbing alcohol overnight. Took it out in the morning and scrubbed the corrosion off with a brush. Speaker works great.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thank you so much! I hope it works☺
さんによる
That’s a great hands-on solution 👍 Cleaning the mainboard with isopropyl alcohol and removing corrosion often helps restore speaker performance after water damage.
For users who want to try a non-invasive method first, low-frequency water ejection sounds can sometimes help push trapped moisture out of the speaker before opening the device:
https://myspeakerfix.com
Thanks for sharing your experience — it can really help others facing the same issue.
さんによる
コメントを追加
最も参考になった回答
I just had this problem. I spilled some tea on my phone speaker. And it started to produce sounds pretty distorted and noisy. Sounds weird, but I didnt have a blow drier, so I just held it above a low flame. So that the heat dries up any moistures inside. And it actually worked like magic. Lol. Good luck.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
True. I was just searching for an affordable option and this right here, my friend, is the bestest option. Thanks man!!
さんによる
Another cheap easy way to clear your speaker is to use speaker clean. It blows water and dust out. If some reason it's not working, I found the song Within - by Daftpunk works. !&&* I think it might work better then the app
さんによる
Thanks a lot to this guy!
I lit a cheap cigarette lighter for a couple minutes at about 6 inches below the speaker port, while keeping my finger close to the bottom of the phone, so I could tell if the phone got too hot to prevent accidentally burning my phone casing or OLED screen.
But first, I put the phone's media volume to max, and I put the phone on YouTube to NBA highlight videos because they're shake-the-phone loud with all the cheering.
For a couple minutes, nothing noticeable happened, and the speaker remained very quiet and crackly sounding. Then within a short second, the volume and clarity was very loud and as good as ever!
さんによる
コメントを追加
Wheneever you get an electronic wet you should always put it in a bag of rice. You could have possibly prevented this.
Anyways.. it is not too hard to replace. You just need to purchase a speaker assembly like this one,
http://compare.ebay.com/like/32095461568...
and look for how to breakdown the phone.
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I just went into a shower with my phone by my side and some moisture probably got into it.
The phone's speakers got distorted and sounded broken.
Then I got out of the shower and put the phone in a Ziploc bag with some silica gel.
within one hour the speakers came back to live!
(Silica gel is better than rice because it does not get mushy when wet)
hope that helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just blow dry it out
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
blowing on it will just have the water go deeper into the phone.
さんによる
Play the song Within by Daftpunk at Max. The frequency range in the song is perfect for clearing water
さんによる
コメントを追加
Hey, I see that things like these can scare phone users as sometimes their minds race to a conclusion that is almost always not what ends ep happening. simply let your phone dry out . give it time, as sometimes water can go deeper within the phone, making it harder to dry. I hope this helped. if this does not work, go to your nearest samsung store and find out its issue. at this time an s3 is almost never used, as an upgrade to s5 and above is a smart move. good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What should I do If my phone fell into the toilet and there's no sound
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Plz help me this phone was brand new
さんによる
コメントを追加
Hi water have gone in 2 my speaker,I put it in rice but nothing can you help please only had this phone two weeks…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yeah i have the same problem, today i was cleaning it with wet paper and i left it for 1 min. And when i started to dry it with my shirt it just had an disorted sound and so LOUD. I was scared what to do and i found this site and i don’t know what to do!
I think you just need to keep phone further from water and left it to dry!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
BatmanForever さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 45
今までの合計 148,186
