メインコンテンツにスキップ
基板とCPUのための修理ガイド
166回答 すべてを表示
type of power supply for supero x7dwt
I would like to know that I have that font installed on this motherboard Supero X7DWT for carrying two 20-pin connectors, and not whether an adapter for the two would serve me.
Update
then I want to say that only connects the jwr1. I have a 850 watt atx power should serve me then.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
ramon vale,
If your computer refuses to boot or tends to turn off without warning, see the Faulty Power Supply to Motherboard problem page for possible causes and solutions.
The manual for your motherboard states that "You cannot use both 20-pin power connectors located at JWR1 (the right side connector) and JWR2 (the left side connector) as input power supply connectors at the same time. Only one connector can be used for input power supply to the motherboard at one time. For proper use of these proprietary PWR Connectors, please customize your PWR cables based on the Power Connector Pin-Out Definitions listed on Page 2-14". You can download the manual from here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
thank you...
さんによる
You are welcome ;)
さんによる
さんによる
Yes, that should work well for you.
さんによる
thank you very much again.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
ramon vale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 769
