メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
Device was dropped, rarely powers on
Was dropped on its left back corner, where the DC in is. I disassembled the whole laptop, and checked the DC in board. Seemed ok. When reassembling, I made sure all the connections to the logic board were solid.
However, it still has the same problem - it simply won't power on. I reseated the ram too, and tried individual sticks on each slot. Still no change. When it's plugged into power, and I press the battery level indicator, it'll flash full.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Hi, Try resetting the SMC. Link on how to do this provided. Good luck.
http://support.apple.com/kb/HT3964
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I forgot to mention that I tried the SMC reset. I just tried it again, and still nothing. And response to the other commenter, when I took everything apart, all the connectors looked like they were connected properly, and as I was reassembling, I double checked it all.
The computer turns on every once in a great while, but it's rare.
さんによる
コメントを追加
reseat flex connector from the keyboard and power button to the logic board maybe its not fully connected or intact....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ben Hodges さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 431
