What do I do if screen is white?
after charging i pod screen went white and will not turn off or on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Reset the iPod:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
このアンサーは役に立ちましたか?
Excellent, thanks for your answer Mayer (immediately solved my problem). Any idea on why the screen went white in the first place? Is this a sign that my iPod will need replacing in the near future?
Saki
I'll start with, there is no "hold" button. Using the pause or not using the pause yields the same result, endless re booting cycle. Getting it into disk mode doesn't get it to show up on laptop so no joy. Glad it worked for 2 people but hardly "solved".
you have to take a rag and wipe off the screen, becuase evidently, you have been watching too much ....hub.com
このアンサーは役に立ちましたか?
funny comment
Solution - Buy yourself a new LCD screen 10 bucks on ebay or you could get it repaired on http://www.missionrepair.com/iPod_Nano_G...
YOUR WELCOME!=]
このアンサーは役に立ちましたか?
Hey how did yours work ? because i droped my ipod and it turned white and when i hold the power button and home button at the same time for atleast40 seconds no Logo apeard on my screen .
Screen goes white by times due to iPod recalibration video
iPod might notice new screen and may not thrust me it happens 50%of time
Don't worry about it
このアンサーは役に立ちましたか?
I followed the instructions and my IPod nano is still white.
このアンサーは役に立ちましたか?
hey did you fix yours because I'm trying to fix my dads and need help
No mine is still stuck on a white screen
Replaced the screen on mine but still nothing. Same white backlight. I am reluctant to try to restore it as some of the songs on there I can't even find online on my phone, and ipod is not backed up. I tried to use wondershare Mobile trans, and while I get songs they are 0 Mb and unable to play. I do happen to know that some of the songs were locked on there with an apple account, and even some apple windows software couldn't copy them without logging into the account. Obviously if I could see the settings I could select trust this computer and then possibly it would take me to the login page if I selected some locked songs. I have an apple ipod nano 8 gb A1236. I can still get the unlocked songs without logging into anything even on files on my Chromebook but any locked songs won't be shown unless I use wondershare, then I can look at the album covers and song titles but nothing else unless I need some more empty files. Files are mp3,0 Mb, have titles and singer displayed but nothing more.
過去 24時間: 2
過去 7 日: 23
過去 30 日: 79
今までの合計 77,116
1件のコメント
Plugging into the stand-alone A/C charger worked for my Nano immediately.
estebanxfernandes さんによる
