メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
How can I reinstall the operating system?
I have had the hard drive replaced. Now I cannot get the OS to install on this computer. It goes through the process of installing, and then gives me a message that "there was a problem installing the software. There is still no system on my laptop. What else could be the problem. All I get is a question mark.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi! I usually get that error when I am using duplicated media. iBook optical drives unfortunately are very touchy and often don't work well with burned media. Regardless of whether you have original/burned media, you might want to try cleaning it, because this error can often just be the result of smudges. if that doesn't help, you can put the media in a newer external optical drive, and load the OS from that, or connect the iBook to another Mac via Firewire, and then put that Mac in target mode and load the OS from the remote Mac's optical drive.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Agreed +
さんによる
コメントを追加
回答を追加する
Mary McMillan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 974
