メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Connector 1 socket probably broken, what now?
I have an iPhone 3G, which worked pretty well except for the battery life. I have replaced the battery successfully, however, the screen stopped working as I assembled the device. It is probably due to the connector 1 on the motherboard as it seems a few pins (not sure if I used the suitable word) are a little bent. Now I have been searching the web and I did not find an answer on how to replace or repair this connector?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
dabestexan, take a look on here. It will show you what is involved with that repair. I do not advise to do it, unless you have the tools and/or the experience. It is an SMD component and a bit hard to solder:-) Try a TV or Electronics shop to get it repaired. If you have trouble locating one, try hectordtruong on here http://www.ifixit.com/User/235262/hector.... The connector is available at places like this. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for the advice. I checked the link you provided already. I'm probably going to head to a local repair shop, perhaps they'll know better.
Thanks again, cheers.
さんによる
コメントを追加
ther are also a couple of places on ebay that are really good and will replace the connector test the phone and have it back to you in a couple days.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dabestexan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 1,059
