How to change the keyboard
how can i change the keyboard, that woes field with water?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Realize that more may be damaged than just the keyboard. The keyboard is integrated to the top case, which is good news because it's a fairly straight forward DIY repair. Just follow the guide. Do purchase the recommended tools, ' every job is easier when you use the proper tools.
BTW everymac indicates the cases are not that different so a 2011 topcase should work on your 2012 machine. To verify I would contact iFixit Customer Service before ordering.
If this answer was helpful please remember to mark it accepted.
このアンサーは役に立ちましたか?
Actually I just ordered the 2011 Upper Case with keyboard and it does not fit 2012 MacBook Air 11"....does anyone know when iFixit will have the 2012 part ?
DG
hey,
a 2011 top case wont fit a 2012 because 2012 has magsafe 2 instead of magsafe 1
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 7,228
