Why my computer is charging but it wont come on
what color do the charging of a battery is fully charge
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The light indicator is green when the battery is fully charged. The light indicator is orange if it is charging.
You can also unplug the battery and just leave the charger plugged in and the computer should turn on. If you try this and the computer still won't turn on, then there is another issue that is keeping it from powering up that would need to be addressed with many more questions.
このアンサーは役に立ちましたか?
well i did this but the indicator is blank but the wifi and the outhers are bright and my screen wont show up
and my screen is always blank when i turn it on
hanif, check with an external monitor. The problem might be your CCFL or inverter or your GPU. Check with a flashlight aimed at an angle against the screen, see if you can make out shadows on your display.
thanks for the help its fixed now :D thanks
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 6,120
3 件のコメント
Have you spilled any liquid or anything on the computer?
Jake Devincenzi さんによる
Ya just a little and it’s says it charging on the cable like it cable button is organe but it doesn’t turn on!
Sophia dizart さんによる
My computer was just on and my cat jumped on it closing it and I reopen it and it's off and I'm trying to turn it on but it won't turn on I plugged it in and it's green I don't know what's wrong?
Savy さんによる
