メインコンテンツにスキップ
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197回答 すべてを表示
締切られた回答
Help ID Burned component on G5 logic board
Hi all,
I am unable to locate the identity of this burned component on the logic board of my Power Macintosh G5 2.0 DP (PCI-X 2)
http://everymac.com/ultimate-mac-lookup/...
It is labeled L32 and resides at the end of the AGP slot nearest the dvi connector. It has no markings or values.
http://www.norcalclan.com/images/IMG_014...
What is it, and what are the values?
Thanks for the help and support.
B
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
As far as markings I dunno. On circuit boards L is typically an inductor. You may have seen their bigger counterparts in older electronics as a wire wrapped around a ring. They are used as current limiters and in passive filters mostly. You may be able to take the part off the board and there may be markings on the backside, but it's hit or miss, it also looks as if you may have some trace damage. If you can get ahold of a schematic and find the value you might try calling digikey (# at digikey.com) and talking to a tech. When they ask about the package it's a surface mount or SOIC.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks. That helped me. I was not able to find a digikey part number even with their online chat help. I took the part off the logicboard and found no readable id numbers even under magnification with light. assuming I find a like computer, how can I measure the smt items specs?
Here is a more detailed pic with the item taken off the board.
Apple PowerMac G5 logicboard smt "L32"
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 604
