メインコンテンツにスキップ
MacBook Proの13インチディスプレイ搭載モデルの修理情報・ガイドです。
9745回答 すべてを表示
締切られた回答
MacBook Pro charging issues after a liquid spill
I was using a Mac Book Pro 13" (Mid 2009 released model) until a day when it wasn't charging. I tried to charge it after few hours and it worked. I did not notice any behavior changes like (Back-lit keyboard, keyboard becoming sticky, Screen) for next few days so I did not care of taking it to Apple Store.
Then after few days, I found its not getting charged again so I took to an Apple store who at first ( As I have a Apple Care) informed that they would replace all the necessary components FREE of charge. Next day I received a call from Apple store informing me that it had some sort of liquid spill on the logic board and does not cover under Apple Care terms & conditions. I was asked to pay $800 to fix it.
And here is another interesting thing..
1. When I used a charger in Apple store (Genius Bar) its getting charged
2. But it does not charge by a similar T-Shape adapter that I was using since 2009
3. Hoping that its a Adapter issue, I bought a new 2012 Mac-safe adapter (not a T Shaped) but it only gets charged occasionally
I took my Mac back home and almost after a 20 days checked (with some hope) if by any chance it would be working or not and BOOM..it was getting charged and working with no issues until I had to recharge it.
With my own research on Web and ifixit, I tried to clean the logic board that had some BLUE color stains on it (very less) using Isopropyl alcohol & Compressed air and put it to dry out for couple of days. Then it again gets charged and works absolutely fine until I had to recharged it...( which now does not detect the MacSafe - No light).
After reading through my Mac's varied behavior of getting charged, can any one help me with their suggestion and recommendations. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
A place to start replacing parts would be the DC in board. You might also want to replace the battery.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for your response. I will try that and see if it works.
さんによる
コメントを追加
Did you try the following:
A) SMC reset
B) Pram reset
C) Battery callibration.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 691
