How do you change the fuel filter in a 2007 Ford Focus?
James, there are great write ups with images on here and another very good one right here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Hi Thank you but my ford is a european focus which seems to have a different filter, do you know of anywhere for these?
Kind Regards
James, here is one for the UK model "it is in a recessed area just ahead of the fuel tank - visible on the passenger side just ahead of the rear wheel. You have to release the fuel pressure with a special hose clamp release tool before removing the hoses. Then there's one small clamp bolt that holds the filter itself.
i am confused now because my fuel filter is attached to the back axle frame and it
does not look like the one in the pics.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 10,229
2 件のコメント
were is the fuel filter on usa ford focus 2007. how do I best change this filter
rick johnston さんによる
hi there
i have a 2007 ford focus 1.6 si hatch back and my fuel filter is attached on the the frame of'
of the back axle. i have seen pics of other cars location and i cant understand why my car is different.
desan さんによる
