leaking power steering fluid
I found out that the high pressure return hose on the power steering is leaking,how do I fix it ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Autozone shows that hose for $120 plus tax and the mechanics labor time is 2.0 hours. I have never done one myself, so I can't comment on how difficult they might be to replace.
Hope this helps,
BILL
このアンサーは役に立ちましたか?
You are right Bill.found it at Autozone and had a buddy who is a mechanic put it on.Everything is all good now! Thanks Bill
Vernon, great job. all you have to do now, is to accept the answer that helped the most. That way, anybody looking for an answer to a similar problem, will know what helped. Good job :-)
I fixed mine using pool putty and stretching plumbing tape rated for hot temperatures. The fix not onlystopped the leak it reduced the vibrations causing fatigue at this union. Fix was only 10 dollars.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 11,191
2 件のコメント
Which Nissan is it?
oldturkey03 さんによる
2000 Nissan Maxima,the pressure hose is quite expensive.Any after market hose that would do ?
vernon さんによる
