Where is the fuse?
My camera does'nt work anymore. I suppose the fuse is faulty.
Is anybody able to describe where I can find it, what it looks like or if it has a marking?
Many thanks in advance,
harripaul
harripaul, your camera actually has 3 fuses. they are listed as follows:
Fuse Parts No. Remarks
FU601 VD7-3642-501 Fuse for the AC adaptor
FU602 CY4-6074-000 Fuse for the battery
FU603 VD7-3641-001 Fuse for power supply charging the main capacitor for flash
Attached is the image with the location of the fuses. Hope this helps, good luck
このアンサーは役に立ちましたか?
Hi,
it's great, your answer with these images has far exceeded my expectations.
Thanks a lot.
Now two other questions have arised:
Which are the nominal values of the fuses? (can't find any data sheets)
Where can I buy them?
I would be grateful for further informations.
Thanks in advance!
Best regards
harripaul
That is a bit more tricky:)
1 CY4-6074-000 MATSU. DENKI UNHS206 FU602
2 VD7-3641-001 KOA TF16AT1.00T FU603
3 VD7-3642-501 KOA TE16AT2.50T FU601
The MATSU. DENKI UNHS206 is most certainly a UNHS200 series SMD fuse 2.3A 50V most common manufacturer is Panasonic and it should be available at either mouser.com or digikey.com The other two fuses are manufactured by KOA Speer Electronics. This link http://www.koaspeer.com/products/circuit... will show you that fuse
FU603 VD7-3641-001 TF16AT1.00T 32V 1A
FU601 VD7-3642-501 TE16AT2.50T 32v 2.5A
Hope this helps.
Hi Oldturkey03,
Many thanks for your prompt response. Thanks to your image I have already found the defective fuse. It concerns the fuse 602 that’s marked with 2.3.
Now I’m trying to find an e-tailer that delivers one or two of those fuses. That’s not easy.
Over here they try to charge you 30 Euros for that tiny thing. It’s a rip-off.
I’m very grateful to you for your efforts.
Best regards
harripaul
I’ve read in your bio >Retired Bundeswehr<. Are you german?
harripaul, ja, war ich ja in Deutschland aufgewachsen. :-) Here is more about my bio :-) Anyhow, let me know if I can help you out. May be if you check on Mouser.com or digikey.com and see what they charge for a similar fuse and let me know what you found. I could send it to you via regular mail:-) Have you on here yet?
Hi oldturkey03,
I have finally found a dealer that sells single pieces of these SMD fuses for only 51 cent apiece. The great manufacturers only accept mass selling.
Now the camera is repaired and I'm totally happy.
Once more: Many thanks!
Harri Philipp
PS:
You wrote :-) Here is more about my bio :-) but I could'nt find it.
It's a pity. I'd like to learn a little more about you.
My email address is: harripaul@arcor.de
I live in southern Germany near Freiburg, Black Forest. My wife and me we both originally come from Berlin. Earlier I use to be an electronic technician, now I'm an old-age pensioner.
Hi oldturkey03,
I was so glad to see my camera working again. But now an other malfunction occured: When I try to take a foto a report appears on the display >There is no memory card inserted< although the card is on it's position.
I have allready checked all lines of the cable tape, they are OK.
Do you have any idea where that can come from?
Thank you in advance
harripaul
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,794
