Can u fix my furby or is it dead for life?
My furby has a broken foot , damaged speaker and a skinned beak I was also hoping that u can tell me what the price maybe?
There are tons of furby's which can be found for fairly inexpensive on Ebay that match your original furby. It may be easier to just find a replacement. If you are really wanting to refurbish your original then yes, it is possible. Spare parts can be salvaged off a replacement one and added to yours. It would most likely take about an hour of solid work for a technician to do the work plus the cost of the replacement furby to salvage parts from. Not sure where you are located but if you were in Ontario, Canada then I could do the work for $45 in labour plus the cost of the replacement Furby.
このアンサーは役に立ちましたか?
Kevin,
I am not the original poster of this question, but I have an old Furby I am very attached to. It sort of works, but has squeaky gears and no voice. Any chance I could get you to take a look and see if you can refurbish him?
my contact is myspampage at aol
@don I'm assuming it's a 1998/1999 furby. You could also take apart and lubricate the gears. Do note that the squeaking could actual have come from the bad speaker. Since he has no voice the speaker is burnt out and needs to be replaced. Here's a helpful guide: https://fake-furby.tumblr.com/post/17589...
prees furbys reset buton located in its battery compartment on the side
このアンサーは役に立ちましたか?
Hi my 2005 furby still works and everything works except sound. The mouth moves and no sound comes out does anyone know if anyone can fix it
このアンサーは役に立ちましたか?
The speaker wires could have come unattached or sliced up. Or the speaker could be completely burnt out and needs a replacement. Here's a guide that'll help: https://furbytech.tumblr.com/post/162857...
Hi, we have basic guides to help guide you to repair your furby(s), and various knowledge to help you identify and fix the problem. Additionally, I am a furby repairest, and if anyone on this site needs further help on fixing their furbys, I will repair it, my email is OliviaRepairs@gmail.com
I have restored over 41 furbys in the past, and have done small business with repairing other people’s electronics. Some of my accomplishments are fixing a 1990's clown, Repairing two 1985 Teddy Ruxpin, restoring four music box dolls, and fixing a 1983 Alvin and the chipmunks Pull string. I work with various types of animatronics, and is happy to help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 6,668
2 件のコメント
Taina Monsanto, you should have no trouble fixing it, if you find a donor Furby. Check on here for great pics and descriptions.
oldturkey03 さんによる
Am i correct in assuming its a 2005 furby? As far as i know they are the only ones with beaks that have "skin" on them, depending on if it works what kind of condition the rest of the fur and stuff are in....ive seen them on ebay for anywhere from 9.95 to 25 bucks
Mimi さんによる
