メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
MacBook is completely dead.
After a hard drive replacement, the computer turned on, but the led light on it blinked like 5 times and that's all. No screen display, it does not respond to any command i gave. It has the install dvd stuck o it and there is no way i can pull it out..
Also the magsafe adapter has no light.
And suddenly, it died. When I press the power button, nothing happens. It's totally dead.
Can it be the Logic Board?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
You have a bad processor:
The power on self-test resides in the ROM of the computer. This test runs whenever the computer is turned on after being fully shut down (the power-on self-test does not run if the computer is only restarted).
If a fault is detected during the test, you will not hear a normal startup chime. Instead, the system will beep as explained below. If you experience one of these beeps, you may call your Apple Authorized Service Provider for additional troubleshooting assistance.
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
In addition to the beeps, on some computers the power LED will flash a corresponding number of times plus one. The LED will repeat the sequence after approximately a 5-second pause. The tones are only played once.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
It could be that the RAM is not properly seated. Remove and reinsert the RAM by pushing it firmly in. Processor won't just die after a hard drive replacement.
さんによる
コメントを追加
Recheck if all the parts are properly reconnected. e.g. battery, ram...
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I did all that, but still nothing happens.. :(
さんによる
Any reason why you replaced the hard drive? Is it for upgrade purpose or is there some other issue on the other parts before the replacement? What is the model # of the new hard drive?
さんによる
yes, the original one was dead. Suddenly the "?" icon appeared at the start up.. And when I pressed alt at the start up, the hard drive never appeard on the screen.
The original one was a Hitachi 250gb 5400rpm
The new one is a Western Digital 320gb 5400rpm
model# WD3200BPVT - 00HXZT3 (is that one correct?)
Thanks a lot guys!
PD: sorry if my english isnt that good.
さんによる
If you have an external usb sata enclosure, try to put your new hard drive on it and plug it in on a different laptop and see if it is recognized. If not then you might be having a bad hard drive. If it is recognized on a different laptop then you might be having a bad hard drive cable.
さんによる
I did it, the original hd is dead, the new one is running correctly. But the laptop's still dead. No matter what hd I put on it.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Benjamin Davila さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,384
