メインコンテンツにスキップ
SonyモバイルとSony Ericssonによって製造されたAndroidセルラーフォンの修理ガイド。
1302回答 すべてを表示
How to change or clean Sony Ericsson W890i SIM card reading device
Display shows: "Insert SIM card, or view a Demo...", but the Sim card is in. Phoneshop told me, Sim card reader must be broken (or maybe only dirty?). Cardcontacts are hidden in the Phonecase, only Card slot is visible. How to open phonecase for cleaning or changing broken parts? I will get a second phone of the same kind, but want to save the memory. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Andy, you can clean the contacts on the Sim card reader, either with isopropyl alcohol or a pencil eraser. It is possible that the pins are not making contact with the card, try to carefully bend them up. Worst case scenario, replace the Sim card module, which is available at places like this. Not to expensive or to difficult to change. No reason to worry about soldering or replacing the logic board. Always start with the easy and inexpensive items first. If you need the service manuals for your phone you can find those on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes! This was the answer i really need. Many thanks for the usefull links. I am sure, it will work in that way. Thank you very much.
さんによる
You are welcome, best of luck to you.
さんによる
コメントを追加
回答を追加する
Andy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,209
