メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Caller name not showing ...
i m using a iphone 4S from sprint. i m using a Gevey card. this phone is not showing any caller name during incoming call or msgs. if i add a contact with +91 then it shows name during incoming but after this i can't reply any msg to that no(like +9198763*****). i can send msg only to without prefix country code.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
i updated the Ios of the iphone to latest firmware 5.1.1 then i changed the Gevey card and program it to new settings acc to their carrier of the phone . This solved the problem of messages and caller name display. i have to do is to save all the number with country prefix . thnx for help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Service providers in the USA charge extra for caller ID sometimes. If your plan is new, the provider may not be providing caller ID. Call and ask them. Also check this on the use of +91: http://countrycode.org/india
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
my problem is that phone not showing name of the contact . it just show the number if i add the +91 with all the contacts then it shows the contact name during incoming . after adding +91 i cannot reply msg or send a new msg to that number . i have to remove the +91 before sending the msg to any number.
さんによる
If your customer is calling from a cell phone, most of the time, in my experience, the name will not show up unless you've programed your phone to show it. Ask if they're using a land line or a cell phone.
さんによる
in india if any calling from any line means cell phone or landline or you have saved that number in your phone's address book then your phone display only name not the number even you have saved with country prefix number or not
さんによる
コメントを追加
guys have got a sure shot solution for contacts and text message issues for iphone users. please visit the below mentioned link and pls do leave a feedback if it helps u.
http://foneadvisor.blogspot.in/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone does not show caller's identity anymore. Used to before.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SIMRAN さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 29,477
