メインコンテンツにスキップ
My click wheel and power button is unresponsive
I've had my 4th Generation Ipod for about 4 years now, and everything is fine i never dropped nor damaged it whatsoever. I used it one day and the click wheel became unresponsive and it shut down on me. I was able to turn it back on but the click wheel became unusable for me to shut it off or even shuffle around. Should i just take it to repair or is there any way i can save my money and fix it myself?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Here's the best answer I've seen on this issue: it seems that there is some design flaw on the the new curved casing on the 4th gen. i've been reading thru different posts and this seems to be a recurring problem and needs to be addressed by apple. the board/clickwheel after a lot of use loosens up and creating some form of unstable contact, a solution i found is by adding a firm backing to it. i did this by inserting a piece of thin plastic (thin old credit card would do) between the board and the aluminum casing on the bottom end of the iPod. tried this with 2 of my iPods and it worked. of course you need to take the bottom plastic cover and the aluminum connector support with the 2 screws first.
Why has my iPod click wheel stopped working?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
okay thanks maybe ill try that. but another concern is, this wont damage my ipod from using it when i put it back together?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
yeah I stiil dont understand how to do it. a video tutorial or some pictures would probally be better.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
richie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,587
