メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
Replaced physical power button. Unit still not turning on. Switch?
After a bike accident, my iPhone 3GS refuses to turn on and off when pushing the top power button. I can use the phone normally by pressing the home button and waiting for the unit to go blank after using it.
I assumed the power button wasn't working so I replaced it today. If feels better when pressed but the unit still refuses to turn on and off. Is the switch (microswitch?) underneath the power button defective? What do I need to replace?
I also want to add that the back case has some cracks but it is underneath a decorative sticker. I don't see any signs of relation to the power button though.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Often when the power button dies, it's because of the ribbon connecting the button as opposed to the physical button itself.
Replacing the Headphone Jack Assembly should fix your problem. You can get very cheap ribbons from places like eBay which I've had no problem with in the past, but iFixit tends to be the most reliable.
iPhone 3G/3GS Headphone Jack Assemblyの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you. I'm also thinking of replacing the back cover since it has moderate damage on it.
I'm trying to figure out if that is also the cause or should I replace both back cover and assembly.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 557
