メインコンテンツにスキップ
2006年11月に北米で発売されたWiiは、任天堂初のインターネット接続に直接対応した家庭用ゲーム機で、オンラインゲームと、Wiiショップチャンネルを通じたゲームやメディアアプリケーションのデジタル配信の両方をサポートしている。
Disc Drive Laser (3350) Has a functioning laser but wont read
Opening up several drives today and all of them seem to have a functioning laser that moves, however they still errored. I read that it may be a calibration issue, just wondering if anyone has any insight on this problem or any other issues that could be causing the error. Going to buy a multimeter now and then test for calibration. Wish me luck
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Sorry for asking so many questions recently but is something like this worth it. I have no experience dealing with aliexpress dealers however I don't see the anti-static solder blob you're describing which I can see in other offerings.
さんによる
コメントを追加
1 件の回答
Hi Jacob!
Usually they do not need calibration.
The lasers are known to fail…. Replacing is your best bet to get the drives fixed.
When I need to replace the laser for a Wii (whenever it is the 3350 or 3355) they work straight out the box.
I just need to remove the anti-static solder blub. Make sure you do this as well! The solder blub is on the ribbon cable. Not on the laser it self.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you, I figured the lasers would just need to be replaced, these are all launch day wiis so I’m glad it’s just the laser that needs replacing.
For the anti static blob is it something that needs to be removed with a solder pen ? There was something on the oem ribbon that looked almost like a screw is that normal ?
さんによる
Looking at the price of the laser is it even worth replacing the laser on its own, seems like its only a couple more dollars for a whole disc drive....
さんによる
コメントを追加
回答を追加する
Jacob H さん、ありがとうございました!
統計データ:
過去 24時間: 26
過去 7 日: 34
過去 30 日: 34
今までの合計 34
