メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
Select Button - Rubber contact pad slippage
I'm having recurring issues with the rubber contact pad underneath the center select button slipping. I've gotten pretty good at disassembling the iPod and re-centering the pad, but does anybody have any suggestions for an adhesive I could use to make a more permanent fix, as I've had to do it five times now?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Joe Seddon, if you are talking about the little black rubber pad that sits on top of the actual switch, I have previously glued mine with cheap rubber cement. I usually stay away from anything else like superglue etc. All it takes is a little dab of the glue, don't go overboard with gluing things together....:) Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Rubber cement was my first impulse, but I wasn't sure enough to just try it. Since someone says they had good luck with it themselves, I'll give that a try!
さんによる
I do it on the once i fix quite often. Have not had a single issue with that. Good Luck.
さんによる
コメントを追加
I just found this answer and figured out that mine was off to the side and the cause of my center button issue. Just not sure where to put the light grey rubber square-U things that fell out though.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Seddon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 14
今までの合計 715
