メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Volkswagen PassatのB6およびB7バージョンは、ドイツの自動車メーカーVolkswagenが製造するフロントエンジン大型ファミリーカーです。PassatのB6ラインは2005年から2010年にかけて、B7ラインはB6ラインのマイナーチェンジ版として2010年から2015年にかけて製造されました。
2012 VW Passat 2.0TDI P0299 code
  • How to troubleshoot a PO299 code on a 2012 Volkswagen Passat 2.0 TDI
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The Volkswagen Passat P0299 code indicates a turbocharger underboost condition, meaning the turbo isn't producing the expected boost pressure. This is often caused by leaks in the air intake system, such as a faulty intercooler or boost hoses, or problems with the turbo's wastegate actuator or a sticking wastegate itself. Symptoms include a loss of engine power, reduced acceleration, and the vehicle entering "limp mode".
Common causes
Boost leaks: These can occur in the air intake system, including cracks or loose connections in the boost hoses, intercooler, or the turbo-to-engine manifold.
Wastegate issues: The wastegate controls how much exhaust gas bypasses the turbo. If the wastegate is stuck open or the actuator is failing, it will cause a lack of boost.
Faulty turbocharger actuator: This is a common problem on many Volkswagen Passats, especially the TDI models, and can be caused by a failing vacuum diaphragm or leaking vacuum lines.
Other turbo issues: The turbo itself may have mechanical problems, such as a binding or worn compressor wheel, which can lead to underboost.
Intake restrictions: A very dirty air filter or a clogged intercooler can also restrict airflow enough to trigger the code.
Faulty sensors: A problem with a sensor in the boost pressure system, like a faulty MAP or boost pressure sensor, can also cause the ECU to register an underboost condition.
How to fix:
Inspect for leaks: Start with the most common and cheapest fix. Visually inspect all boost and vacuum hoses for cracks, loose connections, or signs of oil soaking.
Check the wastegate actuator: Look for any visible damage to the diaphragm or actuator rod. Use a vacuum gauge to test for proper operation, as described in the JustAnswer article.
Test the turbo: If leaks are ruled out, have a mechanic inspect the turbo itself to check for proper movement of the wastegate and compressor wheel.
Check other components: If all else fails, check the air filter, intercooler, and relevant sensors for faults.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Exfiremek さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 109
今までの合計 1,089
