メインコンテンツにスキップ
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
I can not find the flasher relay module?!
I found a bad right turn signal relay in the under hood fuse box ! I just ordered a new relay for the right turn signal side. Now I can not find the flasher relay module?! My 2013 Ford F150 is thought to have a flasher module under the dash board close to the steering column!? I cannot find it! The Google video was for a 2005 F150 so I guess that if my 2013 F150 has a flasher relay module I need to know if or where it is located? Do I need to also remove the panel under the steering column to find the flasher relay module??? PLEASE HELP me to locate flasher relay module or the turn signal module! Not sure where to look?
Sincerely appreciate your support!!!!
Jay Arenson
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@jayarenson your Ford does not have a relay. The turn signals are activated by the BCM (Body control Module) Even the clicking, relay like noise, is fake and generated by the IPC (Instrument Panel Cluster). I believe the relay you found is for trailer operations
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
JAY ARENSON さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 26
今までの合計 26
