メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
fans on nothing on screen no beep
when i power my iBook the two fans are on , led on front is on , but no beep , nothing on screen.
the mac will heat normally as it is working, it seems it is always in sleep mode.
i removed the battery and power up with ac adapter but same problem.
Help
Rana
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
First let's clear the PMU 1. Step 1 Quit all of your active applications and shut down your Mac. 2. Step 2 Once your computer is completely shut down, disconnect the computer's AC power Adapter and remove the battery from your Mac. 3. Step 3 Press and hold down the power button on your MacBook or MacBook Pro for at least five seconds and then release the power button. 4. Step 4 With your Mac still shut off, reinstall the battery in your MacBook or MacBook Pro and reconnect the AC Adapter. The PMU/SMU has now been reset on your computer. Does it start up?
Next we'll zap the PRAM. Hit the start button, hold down the option & command --P & R keys wait till it tones three times then try to start up. Please let us know the results so we can proceed. Thanks
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Good answer +
さんによる 共有
i have the same issue and these steps did nothing for me. I'm thinking its a logic board videoc ard issue.
さんによる 共有
コメントを追加
回答を追加する
haddad さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 31
今までの合計 1,751
