メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released In December 2022. A Laptop equipped with a Intel Core I5 11400H And A GTX 1660, RTX 2080 or A RTX 3050 TI Also Equipped with 512 GB Of storage, 16 GB Of DDR4 Replacable Ram And has a 2nd M.2 NVMe slot, A 144 Hz 1080p screen, RGB Keyboard and 2 HQ Speakers With DTS.
The computer is not responding
I sent my computer to be repaired but they couldn't do it and sent it back. The real problem is that the computer is not responding at all now. It used to light LEDs and stuff like that. Now the LEDs don't light up either. It doesn't light up when I plug it in to charge either. Before sending it to be repaired, I was going to install new RAM but it didn't work. Then I took it out but while I was removing it, the tip of the screwdriver touched the copper plate (I forgot to remove the battery) and a spark occurred and the computer never turned on again after that moment.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Probably a short. Disassemble it further and inspect the damage. Check for burned spots or cracked solder. You might need to send it to a different repairman that can solder new parts
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
BATUHAN さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 38
