メインコンテンツにスキップ
ジョイコンは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
Why do my Joy-Cons disconnect when they are attached?
My Joy-Cons always seem to disconnect after a period of time. This happens when they are attached to the screen; they seem to disconnect in the middle of games and act as if they came off. It tells me to take both off since I have one attached and one detached, even though they are both attached.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
So which side remains "attached" and which side is actually having issues?
Did you tried another Joy-Con, just to be sure?
Otherwise it's the rail that is failing and need to be replaced. Cleaning first is recommended, otherwise you need to replace it.
Example: Nintendo Switch Right Joy Con Sensor Rail Replacement - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
seifhenawy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 14
