The glass on the top is cracked but still works what works?
Only the top glass is really bad cracked still works but the glass is sharp what do i look for to replace and how much will it cost?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
tbates107, here is my answer from a very similar question "the digitizer (touch screen) is available at places like this.For the repair itself, check this repair video" Hope this helps, good luck
このアンサーは役に立ちましたか?
It gonna cost you about $42 to $53 and Atrix 4G front screen digitizer is available at Amazon. This link can take you directly to the product if you wish to from Amazon.
Before purchasing make sure that you're going to get the panel glass also. Since your digitizer is just fine, what you will need most is the glass. Some sellers are just selling Digitizer only. So be careful.
Once you get the glass panel, you will visit YouTube and see step by step video guide to fix it on your own. If the glass panel is not available at Amazon, you can try eBay as well. Cheers!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 704
