Why is my ice dispenser intermittent while in use
Ice and water dispensing cuts in and out during use
Change your water filter inside the fridge the model number is usuallly on the filter itself . If you have hard water the filters should be replaced on a three to 6 month interval . If you connect the water feed from a Reverse Osmosis you can save on filters by using a blank in fridge it acts like a bypass.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 19
Hi @michaelbon86659
What is the full model number of the refrigerator?
Asking as there are 3 models beginning with WRS588FIHZ i.e. WRS588FIHZ00, WRS588FIHZ04 & WRS588FIHZ06 and they're all slightly different.
jayeff さんによる
