メインコンテンツにスキップ
The Expression Photo XP-960 wireless, wide-format Small-in-One printer puts professional-quality photo printing at your fingertips.
Why is my printer just printing purple
When printing black and white it comes out purple
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like for some reason your printer isn't using the black ink cartridge, but rather relying on the CYM cartridge to combine all three colors to make black. However, when your cartridge is out of yellow, you get purple instead of black.
What does the printer say about ink levels? Are your cartridges old and maybe dried out? Have you tried running the cleaning cycle on the printheads?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
These Epsons print black only when the CMY inks are out - if the K ink is out, NOTHING happens. It's probably a clog from disuse or air in the printhead. Some early ones even had the extra fun extra problem (notably the older Artisan series like the 850) of putting the ink in the front and carrying it over tubing like how they do the ET- printhead setup, and those were super fun because you could cause issues with air in the lines.
I wouldn't do a power flush if it's present - it kills NVRAM counter pads. Basic purge MIGHT help, but don't touch the power flush.
さんによる
コメントを追加
回答を追加する
Carol Barmore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 36
今までの合計 36
