How to fix bent port (to the laptop end).
The cord is bent. Will work in a certain position. Otherwise it will not. Anyway I can fix this?
@kit21649 we really would need to know what power supply this is. If it has a common barrel connector, you can replace that one. I would suggest that when you do replace it, cut the wire a bit longer at the connector end. That way you can be reasonably assured that you eliminate broken wires as well. Let u know what power supply this is and if possible post a couple of pictures of the connector with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 17
