メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
20回答 すべてを表示
My iPod is locked for 22, million minutes?
My iPod touch (the 4th generation) has locked for 22 million minutes. And i dont have no clue how to unlock it. Tried connecting my ipod to itunes but it keeps saying that the iPod has to be unlocked to connect to itunes. What do i Do to unlock it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
I am dealing with the same problem except it is over 24 million minutes! I have no clue what to do and I don't really wanna wait 46 years.
さんによる
i have the same problem, my is at 28.4 million minutes. Crazy, there doesn't seem to be and answer on the Apple site either!
さんによる
コメントを追加
4件の回答
最も参考になった回答
corwin turner, here is my answer for the same question "one thing that should work for you is to just connect it to iTunes. iTunes will unlock it for you and you don't have to restore, power off, or anything. Just make sure that you use the computer that your normally use to sync with. The other thing you can try if the first step don't work, is to place the iPod/iPhone in DFU mode and then connect to your computer and restore via iTunes. Connect it to your computer and put it into DFU mode, and then restore it to the latest firmware. You can enter DFU mode by following these steps: 1.) Make sure your iPod Touch is turned on and connected to your computer. 2.) Hold the home and power buttons down at the same time for exactly 10 seconds. 3.) After 10 seconds, release the power button and keep holding the home button for as long as it takes before your computer recognizes your iPod Touch. From here, you need to restore it, by simply clicking restore and it will wipe your iPod of all previous settings and put the firmware back on." Check all of these http://www.ifixit.com/Answers/Device/iPo... for any further answer. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This worked perfectly for me! I was trying to fix my cousin's iPod which has been locked since last year...thanks so much!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Emily Croke, you are very welcome....:-)
さんによる
コメントを追加
STILL WORKS!!! I tried numerous different things to get my sons Ipod unlocked after his brother locked it on him for 22million plus minutes.. I tried for dayssss to get it unlocked and FINALLY it worked!!! THANK YOU THANK YOOU!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do I get my iPod 6th generation to have minutes
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
to have minutes .... what do you mean by that? more clarification needed
さんによる
コメントを追加
回答を追加する
corwin turner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 6,041
