メインコンテンツにスキップ
Amazonから発売されたandroidベースのメディアタブレットで、7インチのマルチタッチカラーディスプレイが搭載されています。修理にはドライバーと開口用ツールのみ必要です。
797回答 すべてを表示
Why wont my kindle fire allow me to display pictures online?
Since getting my kindle fire I have viewed web pages regularly. I have never had any problems until now. My kindle fire allows me to pull the web page up and read the text but if there is a pictures the box stays white and the picture wont pull up. Its really aggrivating could someone please help???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
1件のコメント
I have the exact same problem with a very sudden onset! Although it's 2020 now, I have the fire hd 8. The show image option seems non existant..i can't locate it ANYWHERE! I did the factory reset and apparently,enough my kindle has a regular backup schedule and showed a recent backup...nothing was actually backed up. So...I lost a lot of content AND it did not bring back my ability to load images. The odd thing is,this is a problem usually occurring on shopping sites like hsn,acc etc the scrolling ads show up but merchandise images do not. I get a white square and place holder right after the images flash on the screen. I attempted to use a different browser, got firefox, it works but so slowly you'd think I'm on a landline dial up! I have the highest upload speeds available in my area and we use xbox with no speed issues,watch movies with no issues but loading images on the kindle?...nope! Can anyone help please?? Thanks!
さんによる
コメントを追加
5件の回答
最も参考になった回答
terri, check the settings on your browser. Open up the browser, hit the menu button at the bottom of the screen, hit the Settings button, and try to enable your plug-ins and see if you are in mobile or desktop view. See if that makes a difference.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Ok that didn't work but I went to settings and scrolled allthe way down to default settings and hits ok and BAAAM that totally loaded all the pics thanks for ur help
さんによる
Good job, happy browsing:)
さんによる
コメントを追加
bold textGo your upper left hand corner when you are in SILK. Hit the three bars, the web page will slide to the right and the term web content will appear at the top. Select settings then select advanced. Then check the box to show images. And you're done.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hey - I also had the same problem - no pictures showing up on a web page. Did the reset and like oldturkey03 says: BAAAM! Images now showing up.
Thanks -
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks you guys!!! I was having the same problem and busy surfing the web looking for a solution!!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Fire Tablet won't open window only withJPEG
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
terri さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 71
今までの合計 31,091
