メインコンテンツにスキップ
ジョイコンは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
Why do these things break so easily?
This isn't a repair question, per say, but if anyone knows why these things break so easily, I'd really like to know, especially when it comes to how the R-buttons are so flimsy! I took two apart, and both had serious problems, especially with the R-buttons. As soon as I touched the internal button, it pretty much dismantled itself. I have no clue why this happened. The remains had carried small flakes of the circuit board with them, so I'm not sure if I'll have to replace the board or just the buttons, because I don't know if it carried too much of the conductive surface away with it (if anyone knows the answer to that, that would help, too!). I'd also like to know why it's almost exclusively the R-buttons that break (at least, among the shoulder buttons)! So far, I've only had R-buttons break. Not L-buttons. Not those ZR/L buttons. Just the R-buttons! Anyway, if anyone knows why these things are so dang flimsy, I'd appreciate it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Yes, it's very common that the R and L buttons are breaking. The R button is breaking from the motherboard with it's legs and taking the traces from the motherboard with him (most of the time). Also had a few with a broken "L" button, but this one is easy to replace as it's not soldered on the motherboard.
If you ask me, the soldering is very bad and the component is cheap. One drop and it litterly breaks completely and will rip from the motherboard.
You can replace the board, but this will be more expensive. As when it breaks it most of the time take the traces from the motherboard with him. So, you can fix it with soldering and repairing the traces. If you don't have any experience with this, replace the board (there are many for sale at AliExpress) or get it to a local repair shop.
If you have any more questions, please let me know!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I can solder, but my main concern is that it wouldn't work because as I said it looks like it took the conductive pads with it when it popped off. My soldering iron is also really old and long, so I'm not sure it would be very easy to use on this. The smallest thing I've probably soldered are some USB leads in a third-party USB controller from CORE INNOVATIONS. Anyway, the spot where the pads were now has some pale red spots, about the color of a faded brick. My concern here is that there's not enough conductive surface for a new button to even function. I also can't find the right button for it. That is, as of the moment, I have no way to tell if it's the right size of button. I'm also not sure if I'd be better off just wiring in a larger button that would be easier to repair, along with better durability. I've also looked on Amazon, which has a pair of third-party joy-cons for sale at less than the cost of a new motherboard. At the moment, I still intend to repair this pair, if at all possible.
さんによる
I would also like to add that these joy-cons have not been put through much more than regular use. Aside from an occasional drop on a carpet, all they've been through is normal use. If a product breaks simply because of that, it shouldn't be produced in the first place. I have a GameCube, which is in practically new condition in terms of functionality. The controllers for it are no different. I've only had one break so far, and that was because of a malfunctioning C-stick (it was completely unresponsive to anything). These joy-cons, on the other hand, are pretty much the opposite of the GameCube controller. They break easily, and aren't nearly as comfortable to hold, and are just all-around terrible.
さんによる
Yes. That means that the whole solder pads came off, unfortunately… so you need to repair the traces to get that fixed, which is difficult to do… you need to carefully scratch it, to reveal the copper. This is different from soldering.
So, soldering in a new button won’t work as there is nothing to solder the legs on :(..
Gamecube controllers and Nintendo 64 controllers are known as strong. Their soldering is better. But also they have weaknesses. Like the movement stick (N64 controller). And the L/R plastic buttons on SNES controllers and the conductive pads on the board came off.
But yes, the soldering part was good. From now one, it’s required for them to use “lead free” solder, which is way worse then leaded solder. It’s giving issues.
So, long story short, those new controllers like Joy-Cons are so complex, the whole motherboard is filled! If something fails on there, it could cause serious issues. They are using cheaper parts, it should not last your life long as the old controllers should have…
さんによる
コメントを追加
回答を追加する
Fixer of Stuff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 45
