メインコンテンツにスキップ
Suzuki’s AE50 was introduced in Canada in 1990, seemingly as a competitor to the popular Yamaha Jog and Honda Dio.
1回答 すべてを表示
cant start the moped after been stored.
We have a 1991 suzuki AE50 moped, we removed the battery and had the moped stored for 4years now we charged the battery checked the spark plug but the moped wont start can you help as to the promblem Thank you ...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Theres a very good chance the carburettor is full of dried fuel. The metering jets are almost certainly plugged and not allowing any fuel through. If the motor spins and the plug sparks, but comes out bone dry you aren't getting any fuel to the engine. You need to remove the carb, strip it and clean it out, a workshop manual will run you through the procedure, either a Haynes or Clymer manual will do.
Its a pretty common thing to happen to bikes/scooters after a long layup.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
+1 Big Pete:). Rita, on here for a general description on how to fix your moped. Here is the online parts list for your moped. Hope you enjoy your moped.
さんによる
Will they start with out a battery or no
さんによる
コメントを追加
There is a vacuum type valve that the gasoline from the tank connects to and from there too the carb it also has a vent tube and a vacuum tube . This tends to stick it can be exersised by the vacuum line but is not that expensive just hard to get to. If you want to sell I need a front end for mine (i_byer2@hotmail.com)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rita さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 2,097
