メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for top and front loading Whirlpool brand washers.
Washing Machine Grinding Noise?
Help appreciated. My washer machine is making this horrible grinding noise during wash/ agitate cycles. I attached a video. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@emilielaky what is the exact model number for your washer?
さんによる
@oldturkey03 model number is HSWP1000M4WW there's also a serial number SF176616H. thanks!
さんによる
コメントを追加
1 件の回答
Grinding noise on a Whirlpool top-loader almost always comes from the drive components under the tub, not the motor itself. Based on the sound in your video, these are the two most common causes:
1. Worn agitate dogs (agitator “dogs” / cam kit)
If the noise happens during wash/agitate, the plastic dogs are stripped and slipping.
Cheap and easy fix — the top of the agitator comes off and the kit drops in.
2. Failing gearcase / clutch assembly
If the noise is heavier and continues through both wash and spin, the transmission gears or clutch are wearing out.
This creates a grinding/rumbling sound exactly like what you described.
Quick checks you can do:
Try spinning the agitator by hand — if it slips or clicks, it’s the dogs.
Tilt the washer back — look for oil leaking from the gearcase (a sure sign it’s failing).
If you can upload a 5–10 second close-up of the sound from the bottom of the machine, I can tell you which one it is for sure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Emilie Laky さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 18
今までの合計 97
