メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Corrosion on female end of MagSafe?
Hi everyone-
It would appear that after a long time of just answering questions it's my turn to ask a question.
Well so I've noticed that now the female end of the MagSafe connector on my MacBook looks like it has corrosion (or something else) there is discoloration and it looks like the port is "gunked up" or dirty somehow. What I want to no is if anyone can confirm that this is corrosion and/or explain how to clean it. I've heard simple rubbing alcohol and a paper towel will work, but I'm not sure.
I've attached a picture to show the issue.
Thanks for any help whatsoever!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Oh and I should add- it charges just fine.
さんによる
コメントを追加
2件の回答
ベストアンサー
Try contact cleaner and a toothbrush or a stiff solder brush. Ralph
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
So just hydrogen peroxide in general?
さんによる
I'm not sure about that product==I always use electronic contact cleaner. You can get it at Radio Shack. Ralph
さんによる
Do you mean electronic contact cleaner or contacts cleaner? If you mean the former then I'm not sure, but contacts cleaner is generally something along the lines of .02 H2O2
さんによる
Electronic contact cleaner. Ralph
さんによる
Looked it up-- part number 64-4345 Precision Electronics Cleaner. Ralph
さんによる
1以上のコメントを表示
コメントを追加
I have a MacBook that looks just like that- I tried cleaning it with alcohol, but it didn't really work. To be honest, I think it's just discoloration from the magnet rubbing. It doesn't seem to be detrimental at all, so I just left mine alone.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm worried about build-up over time though, and I don't think it's discoloration.
さんによる
コメントを追加
回答を追加する
rab777hp さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 3,795
