メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2024年10月に発売された、アップルの人気スモール・フォーム・ファクター・デスクトップPC「Mac mini」の3度目のメインモデルチェンジに関する修理ガイド、分解、トラブルシューティング情報です。 M4およびM4 Pro SoCと最低16GBのユニファイドメモリを搭載しています。
Mac Mini - no hdmi and blinking red
I usually switch my monitor between my Mac and PC. One night, my Mac mini’s screen wouldn’t turn on—I thought it was just asleep, but it wasn’t.
I thought the storage becomes faulty since I upgrade it but I tried using the original storage but I got the same result.
Here’s my situation: after plugging in the power, the Mac mini’s light keeps glowing on and off. When I press the power button, there’s no chime or response—just the same pulsing light. The dock station connected to my Mac mini isn’t turning on—there’s no light on my mouse.
Here’s the thing I have tried.
  1. I hold the power button to turn it off. Then I press it after again. I can hear the chime and there’s white light glowing for a while after a several mins the light will turn to blinking red.
  2. I have successfully “revive” the original storage but still the same result.
  1. Also I just found out that the dock station slot I use to connect my Mac has a blinking light, which means it’s having trouble maintaining proper conductivity. The other slot works fine. Also only the mouse is connected to the dock station so believe I'm not overloading on it too.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント:
To be clear the front normally White LED is now blinking Red?
さんによる
its white glowing for a while after a several mins the light will turn to blinking red
さんによる
@macuserzat172 - the system will need a DFU reset. Best to let Apple do this that's assuming the original NAND still fails the same which I think it will.
さんによる
Is that wherein you have option to restore or revive the mac? yeah I have succesfully revive the original NAND but still the same. I'm trying to restore both of the NAND but im having some issue.
さんによる
@macuserzat172 - time for that visit to the mount of Apple for there skilled workers to fix your system under warranty! But the clock is ticking, don't loose the window as if they are unwilling it will be costly!
さんによる
コメントを追加
1 件の回答
Your system should still be under warranty, I would get to an Apple Store or authorized reseller to get it looked at. This doesn't sound good!
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
wait I thought I already void my warranty after opening the unit since I upgrade my storage.
さんによる
@macuserzat172 - slide in the original Flash I won't tell 😁
さんによる
Apple nabízí bezplatnou opravu, ale jen pro určité s/n
Apple offers free repair, but only for certain s/n
さんによる
@vladimirneuman - Není to definováno sériovým číslem systému, ale stářím systému, dva roky od data zakoupení, a Apple vám v tomto ohledu také dá trochu prostoru pro manévrování!
It's not defined by the systems serial number it's the age of the system, two years from date of purchase, and Apple will give you a bit of wiggle room as well on that!
さんによる
Our seller provides a one-year warranty, so I was excluded from the repair.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
macuserzat172 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 33
今までの合計 406
