メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年6月8日に発売。A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor.
Every task running slow
My Imac has been running extremely slow on all tasks, booting up, browsing the web, openinig a folder or file, launching an app.. ect.
Even after ive removed a lot of redundant files, cleaned and scanned the drive for malware, nothing seems to fix it
Sometimes If its being used for a period of time its slow but not too bad. its almost like its warmed up.
But if left for a while and you come to use it it takes a while to get going. sometime you might be waiting over a minute or two just to open a file
Anybody experienced the same thing? Any ideas? Could the hard drive need replacing?
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is your system a Fusion Drive?
Have you run the system Diagnostics? Restart the system and press the D key to enter Use Apple Diagnostics to test your Mac yet us know what it reported.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
thanks for the reply
I no idea how to check its a fusion drive system.
Ran Diagnostics and all seems to be OK
I do have a couple of screen shots but it look s like im unable to upload in here
No issues found
Reference code : ADP000
Then it goes on about support.
I also ran first aid on the volume
That operation was successful.
The drive itself is a 1TB with 913gb available.
Is there anything else you can suggest I try?
Thanks
さんによる
@wayne16803 - I'm leaning on a failed SSD drive. A Fusion Drive is two physical drives a SATA HDD and a second hidden SSD drive which is used as a Cache drive to the HDD. To prove this is the fault you'll need to have an external drive which your system uses as its boot up drive. Here's the hidden SSD iMac Intel 21.5" Retina 4K Display (2017)ブレードSSDの交換.
Do you have a drive you can setup as a bootable external drive?
さんによる
@danj
Sorry for the long delay in replying. Ive set up a pen drive to boot from.
Im assuming its just a case of running first aid on the internal drive?
OK ran it on all drives that appeared under internal and all passed apart from the parent (drive at the very top)
'problems where found with the partition map which might prevent booting
counld't mount disk. :(-69842)'
What does this mean and is there anything else I need to run or check?
さんによる
@wayne16803 - Well that's not good! The SSD is having problems. You should backup your stuff ASAP as you need to reformat the drive. Hopefully that fixes things.
さんによる
コメントを追加
回答を追加する
Wayne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 51
