メインコンテンツにスキップ
内蔵ハードドライブからネットワーク接続用ドライブを含む様々な種類のストレージデバイスの修理ガイド。
How to remove heatsink Samsung 9100 SSD
I bought the Samsung 9100 Pro with heat spreader/heatsink (low profile) thinking it should fit, if not I could remove.
Samsung used what might be star screws because T5 Torx doesn't work and T6 is too large.
Can someone confirm type and size of the bit I need?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@tumanwk we have to see what the screws look like. there are to many aftermarket suppliers and we do not know what this particluar one may have use. iFixitでの質問に画像を追加する方法
The ones I have seen were P5 (Pentalobe) screws
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the quick response.
You guessed correctly it's pentalobe, I have to find where I miss placed my iFixIt Pro Tech Kit... Just verified the P2, P5, and P6 should be in my kit online. Now I just need to remember that wonderful location I moved it to, in order for it to be easier to find when needed.
My other kits are older and do not contain this bit style. I think unofficially when Apple started using these screws people referred to them as star bits .. but that didn't work, I figured best to ask the experts here.
Besides the training classes for Apple, (did phone technical support CPU/Computers) I haven't had to use Pentalobe screw bits/driver.
さんによる
コメントを追加
回答を追加する
Tuman WK さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 106
過去 30 日: 352
今までの合計 697
