メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Remove space bar to clean under it
Hi,
my space bar is over reactive. It writes a " " when I lay my finger on it. Quite hard to write longer texts with it. I'm expecting dirt under it, do you think so too?
How to remove the space bar without destroying it? Thanks for your help.
Greetings
Chris
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Get the tips of your pointer fingers slightly under the top edge of the key, press down on the bottom of the key with your thumbs, and with a firm and somewhat forceful motion, pull the key back very quickly from the top. It's like removing a bandaid -- do it quickly. If you do it slowly, you run a higher risk of damaging the internal components.
Most of the spacebars have a couple metal bars running the length of the key. Their ends need to be secured in tiny holes at the base of the spacebar area, however the metal bar, especially the top one, often comes loose when pulling the key back. Make sure the ends are properly seated in the holes, and make sure the upper bar is flipped upward so that it runs against the top of the spacebar area (if it is in the downward position, it will not fit into the notches on the underside of the spacebar). The bottom half of the spacebar can remain connected while it is pulled back from the top. As for working inside the key, I prefer using tweezers, because other instruments tend to be too blunt.
Once everything looks good, position the spacebar back in place, and press it firmly downward with several fingers. Press your finger across the entire length of the key in order to make sure all of the clips have secured themselves.
Please note, there is always a risk of breaking some of the small plastic clips when removing a key. no matter how good you get at it, you will probably break a key every now and then. Although, like I said, pulling it back very quickly helps reduce the potential for damage.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You use a toothpick to pop off http://www.youtube.com/watch?v=E--mfTViQ...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I'm afraid the spacebar is an entirely different animal....
さんによる
コメントを追加
http://www.youtube.com/watch?v=IIpgG9fHc...
might be similar to this.
kind regards,
Rens
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's relevant, but he's making it a bigger deal than it needs to be -- you don't have to completely remove the spacebar. If you just fold it back and leave the bottom connected, you get the same result in less time, and there's less risk of damage.
さんによる
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 7
過去 30 日: 7
今までの合計 2,692
