Looking to do a VEO Cosmo Conversion
So as the title suggests I'm trying to convert a VEO Cosmo that I've had sitting around for a while. I've done all the research I can on how to convert it already so the first two pictures are from someone else's post that was trying to do the same thing, the third picture is of the motor controller that I took off of mine with the wires already stripped, and the last picture is of someone on another post explaining how to do it. So I'm in the process of getting the battery case open which has turned out to be a little more difficult than I originally thought but it shouldn't be a problem. So my only question is what motor controller should I get to replace the old one? I want to get a cheaper one for now to make sure everything works then upgrading to a better one later on. I'm going to put links from a few of the controllers I was looking at on Amazon so if someone could tell me which one would be the best and I'm open to other suggestions as well.
https://a.co/d/3t2dR7u
https://a.co/d/ipIpqFZ
https://a.co/d/bCMRA2I
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
