stop lights not working
I have no stop lights check break light switch good it's blowing fuses
@stevepucke73877 if it blows the fuses when you apply the brakes you have a short circuit. This will be either along the wiring harness or in the bulb socket. You will have to check by using a multimeter in ohm mode. If you are unfamiliar with this check something like this video and I would start on the light socket itself.
Here is the wiring diagram for the '99 S10 but it should work for the Xtreme as well
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 119
