メインコンテンツにスキップ
The Shark DuoClean Vacuum HV391 is a wired handheld vacuum manufactured by Shark™ for home use.
HV391 - How to permanently stop the roller brush
I have a need to permanently stop the roller brush so I can use this vacuum only on rugs that would be damaged by a rotating brush (I've got a newer vacuum for the other floors.) Looked for the switch that turns the brush off when the wand is locked upright and couldn't find it. Any ideas on an easy way to do this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @bobg54562
One way would be to remove the drive belt. That would stop the brush from rotating.
Here's the ifixit Shark Flex DuoClean Drive Belt Replacement guide that may help.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks for your answer. Probably the right way to do it, but I figured out a lazy way. If I leave one side of the garage lid loose the roller brush won't turn.
さんによる
@bobg54562
If you leave the lid loose won't that mean the dust will come out of the cannister when vacuuming?
さんによる
@jayeff I think I've figured out how to leave it just "slightly" loose. So it's loose enough so that it doesn't engage the switch, but still tight enough to keep the suction good and all the dust where it belongs.
さんによる
コメントを追加
回答を追加する
BobG さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 43
今までの合計 98
