Hardware Question Based on Step 5 of the Circle Pad Replacement
While following the circle pad replacement guide, I've ran into an issue. I can't seem to remove the bottom right screw in the 2nd image, circled in yellow. When I initially opened it, it's the one that just was not turning, and now I've %#*@ near stripped it. How can I hope to remove it without damaging my "NEW"3DS XL? Do I risk using a bit of super-glue to set the screwdriver, and remove both? I don't know if it's safe to do with an electronic device like this.
Hi Stevo! Are you able to sent us some pictures? And do you mean the screws that are related to the backplate where the battery is? Thanks!
koppie007 さんによる
