メインコンテンツにスキップ
How to fix PS4 dualshock controller right joystick stick drift
The right stick when pressed down just moves the camera up when pressed to slide in a game like Fortnite and when aiming it's not stable and moves by itself in any direction so I constantly have to pull it back to track a player in a game
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The Dualshock 4 controller uses potentiometers for sensing joystick positions. Since these are mechanical sensors, they wear down over time, usually within a year or two depending on usage.
Sometimes you're lucky and there's just some dust inside the potentiometer that you can remove with a blower, most more often than not you will have to purchase either a replacement joystick assembly, or new potentiometers, and perform some soldering in order to fix stick drift on these controllers.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tshepang さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 10
過去 30 日: 24
今までの合計 96
