How did water get inside by the control panel?
Shorted out my control panel.
Hi @junecallen
What is the model number of the washer?
If the washer is a top loader, check if the temperature sensor is plugged in securely into the small tank in the control panel.
With a lot of F&P top loaders, the tank is located behind where the hoses enter the machine.
It could also be due to a leaking inlet valve pipe connection etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 33
