What are these contacts called and how to replace them?
I tried to repair my phone. Its a Samsung Galaxy A52s 5g. This is the third time my phone is not able to charge because apperently it is too cold (It does not charge if it measured a too cold temperature. The sensor reading is wrong as i found out by checking the measured value). The defect sensor is on the daugter board. Thats why i wanted to replace it again. Then i noticed that one contact the board connects to on the frame was loose. It was some kind of tiny plate. Its the golden contact i highlighted in the picture. Would that be a problem? Because after the switch to a new daugter-board charging still does not work for the same reason. If it is how can i replace it? I cannot find a place to buy contact pads like that. How are these attached normaly? Are they glued?
Here are pictures of the Board and the missung contact
この質問は役に立ちましたか?
2 件のコメント
So as @oldturkey03 wrote it was the main flex cable. My phone works again now after i swapped it too. The contact pad was not needed. I just left it out and my phone still works without issues. Not even any problems with the wifi as he suggested could happen.
Kenedikt さんによる
@kenedikt Great Job fixing it! Glad it all worked out okay.
Repair is War on Entropy!
oldturkey03 さんによる
