Will LCD from a 1 GHz Titanium work in my 550 MHz?
Just what the title says. I've researched the models and their native resolutions are not the same. Still, I have to ask the question. Are they interchangeable?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The 550 uses Apple part #661-2568. The 1GH uses 661-2748
Apple Part Number: 661-2539, 661-2539-A, 661-2568
LTN152W1-L01, LP152W1 (A1AP), LP152w02 (A1)
Compatibility
PowerBook G4 Titanium Mercury (400/500), PowerBook G4 Titanium Onyx (550 & 667) VGA Model
Apple Part Number: 661-2748, 661-2748-A-R
B152EW01
15.2-inch (1280X854) LCD panel and upper case assembly for a 667MHz / 800MHz / 867MHz / 1GHz (DVI) PowerBook Titanium.
This LCD assembly will not function properly in the 400 / 500MHz (Original) or the 550 / 667MHz (Gigabit) Titanium Powerbooks.
このアンサーは役に立ちましたか?
Thanks for accepting my answer.
It works… but the resolution doesn’t get all used. I’m trying to hack MacOS with SwitchResX or something else to override the display settings. I’ll let you know if I can get it figured out.
このアンサーは役に立ちましたか?
過去 24時間: 13
過去 7 日: 23
過去 30 日: 30
今までの合計 772
