メインコンテンツにスキップ
The GeForce GT 1030 was an entry-level graphics card by NVIDIA, launched on May 17th, 2017. Built on the 14 nm process, and based on the GP108 graphics processor, in its GP108-300-A1 variant, the card supports DirectX 12.
Display not output by graphic card
I plug my graphic card in slot when I plug display output cable ( hdmi ) but I screen the no device connected shows even I change my cable also
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Do you have a second monitor or system to verify if the display is working or even try a second system to make sure the video slot is not damaged. If the card is still not sending a video signal then you've isolated the issue to the card and will need to dig into the cards logic, that will require component level diagnostics.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Apurva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 126
